gss image upgrade
Answered Question
Mar 19th, 2009
greeting,
I have tried to upgrade image version from 2.0(2) to 3.0(2) for my GSS4492R.
according the gss upgrade doc for version 3.0 I did:
gss4492r#gss stop
gss4492r#install gss-3.0.2.0.0-k9.upg
File: gss-3.0.2.0.0-k9.upg
Md5sum: 3f1e74d26dc0e4fcaae4759b574009c9
Proceed with install (the device will reboot)? (y/n): y
Performing software install. This will take a few minutes.
If you close this session, the installation will still complete.
% Upgrade failed: The install script from the upgrade file failed.
% The GSS is not running.
It seems can not upgrade for me. Could I get some advice about the problem?
Any comment will be appreciated'
Thanks in advance
Correct Answer by andrew.burns about 8 years 12 hours ago
You can't upgrade from 2.0(2) to 3.0(2) directly, as there is an intermediate upgrade required.
See this link about the sequence:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/gss4400series/v3.0/administration/guide/Upgrades.html#wp1010257
Andrew.
Overall Rating: 5 (1 ratings)
