Cluster CM6.1 - Testing Redundancy and Fallback
abartolomeu
Hi!
How can I be sure that the redundancy offered by the cluster solution is really working? I mean, how can I be sure that if the publisher crashes, the subscriber will guarantee the CM services?
Ana
Jaime Valencia
first of all check your CCM groups config and confirm the phone has both in their config, then:
a) stop CCM service
b) use an ACL to block communication phone-ccm
java
if this helps, please rate
java
Hi!
On System > Cisco Unified CM Group I can see the Publisher and the subscriber. Is this enough to check CCM groups config?
On one of the phone's browser page I have on the network configuration:
CallManager 1 (CM Pub. IP)active
CallManager 2 (CM Subsc. IP)suspended
CallManager 3 (gateway IP)
Does this seem OK?
yes, that seems fine on config, now you need to test it
java
java
