Custom SIP header in INVITE msg: OK w/941, NOK w/962
pgraziol
I'm facing an issue with custom INVITE messages (sent from an Asterisk box) in order to choose the ringtone.
The SPA941 phones (latest FW - and it was already working fine with old 4.1.8) play the correct ringtone specified in the custom header, while the SPA962 (+SPA932) doesn't (FW 6.1.5a) and keeps playing the default ringtone.
These are the strings (ext 200 is the 962 and 201 is the 941) :
exten => s,50,SIPAddHeader(Alert-Info: n=Office)
exten => s,51,Dial(SIP/200&SIP/201,60,t)
Thanks in advance,
Paolo
Message was edited by: Paolo Grazioli (typos)
13 Replies 13
Patrick Born
Hi Paolo,
I'll research this and get back to you.
Patrick
Hi Paolo,
I've not forgotten this, apologies for the delay.
Can you please verify the following please? SPA962 web-ui > Phone > Ring Tone > Ring10: n=Office;w=4;c=1
This setting and name should be identical to the working SPA941.
I'm building an Asterisk server in order to verify this for myself.
Patrick
Hi Paolo,
I've built an Asterisk server and configured a SPA962 running 6.1.5(a) firmware.
I configured 2 phones,SPA962 as ext200 and SPA942 as ext201 with:
exten => 200,1,Dial(SIP/200)
exten => 201,1,Dial(SIP/201)
This causes both phones to ring with the default Classic-1 ringtone.
I then modified ext200 as follows:
changed from:
changed to:
exten => 200,1,SIPAddHeader(Alert-Info: n=Office)
exten => 200,2,Dial(SIP/200)
Now when I dial 200, it plays the Office ringtone.
I couldn't get the syntax that you supplied to work, probably due to me being an Asterisk rookie. However; I was able to prove that the SPA962 does support playing a custom ringtone within an Asterisk environment.
Here's a trace of an INVITE without the header:
Session Initiation Protocol
    Request-Line: INVITE sip:200@192.168.2.14:5060 SIP/2.0
    Message Header
        Via: SIP/2.0/UDP 192.168.2.19:5060;branch=z9hG4bK2fa6e5a8;rport
        To: <200>
        Contact: <201>
        Call-ID: 6ff6e04d6cffd79a3c3999bb48f958ea@192.168.2.19
        CSeq: 102 INVITE
        User-Agent: Asterisk PBX
        Max-Forwards: 70
        Date: Wed, 25 Mar 2009 19:58:41 GMT
        Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
        Supported: replaces
        Content-Type: application/sdp
        Content-Length: 287
    Message Body
Here's a trace of an INVITE with the modified header:
    Message Header
        Via: SIP/2.0/UDP 192.168.2.19:5060;branch=z9hG4bK0458f79b;rport
        To: <200>
        Contact: <201>
        Call-ID: 23f6582d3df9e52167d8ed223011e71d@192.168.2.19
        CSeq: 102 INVITE
        Max-Forwards: 70
        Date: Wed, 25 Mar 2009 19:55:17 GMT
        Supported: replaces
        Content-Length: 287
    Message Body
Please let me know of any progress.
Patrick
Hi Patrick,
sorry for the awful delay of my reply.
It works perfectly!
So yes indeed it's possible to choose the ringtone on all the SPA phones.
The 's' in the original exten statement should be something related to macros, as far as I understand (I'm a complete Asterisk newbie).
I'll go on studying Asterisk tutorials... It wasn't very clear to me how the syntax works and I guess the statements were a bit messed up.
Paolo
Paolo,
No problem about the delay. I understand what it's like to have lots going on. :-)
Thanks for letting know that the issue is resolved for you.
Patrick
Hi Guys,
I've tried the exact same line:
exten => 225,1,SIPAddHeader(Alert-Info: n=Office)
with my SPA-942 (Software version 5.1.15(a)) and Asterisk 1.4 this does not seem to change the ringtone. When I debug the SIP traffic, I do see the SIP header being sent to the phone.
Is this software dependant?
Thx!!!
Hi bartconinckx,
It could well be software dependant. Consider upgrading the phone and trying again.
The header says SPA962 but the body mentions SPA942. In my lab, I used a SPA942 running 6.1.3(a) when I worked this issue for Paolo.
Patrick
Patrick,
thx for your usefull answer. This probably will be the reason. It's a pity there are no "bulk" upgrading tools, 'cause now I have to do 70 phones manually. Or perhaps I should check the docs if the firmware is upgradable via TFTP.
I'll try this ASAP!
Thank you!
Bart
Hi Bart,
There are several ways to upgrade these types of devices:
     1. Run the firmware utility [Windows only] and upgrade each phone
OR
     2. Upgrade by URL by causing the phone to request an upgrade:
            http://IP_Address_of_SPA-Phone/upgrade?tftp://IP_Address_of_TFTP_Server/PhoneFirmwareBinaryFile.bin
               Described in more detail in https://www.myciscocommunity.com/docs/DOC-5938
OR
     3. Write a config file containing the upgrade instruction and then:
          a. Use phone Setup button > Profile Rule > http://IP_Address_of_Server/PhoneConfigFile
     OR
         b. Send the phone a resync:
          http://IP_Address_of_SPA-Phone/admin/resync?tftp://IP_Address_of_TFTP_Server/PhoneConfigFile
Patrick
Hi Patrick,
most usefull info!
Before your post I already had upgraded one phone with the 6.1.3a firmware and now it indeed works. Me happy :-)
I will do a batch upgrade for some phones, test them for a couple of days and then do the lot.
Thanks again,
Bart
Hi Bart,
Great, thanks for letting me know. Please consider sharing any insights that you gain so that others in the community can benefit from your experiences using the SPA IP phones in an Asterisk environment.
Patrick
OK, Patrick, I will.
So, inconclusion, doing the firmware upgrade did allow me to send the SIP header and change te ringtone.
I upgraded by using TFTP on my Asterisk server and filling out the "Upgrade Rule" on the provisioning tab of the SPA942. Worked smoothly.
Thanks for the update Bart. I'm glad that it's working for you.
Patrick
