CCNA ACTIVE STATUS--CCNP
Mar 19th, 2009
Hi Guys i needed some clarification so i dropped in for a professional advice.
I gave my CCNA in May 2006 and is ABOUT to expire this May.
1. My question is if i have to maintain my CCNA status as ACTIVE do i need to CLEAR all the FOUR papers of CCNP?
http://www.cisco.com/web/learning/le3/learning_about_recertification.html
2.This link says Pass any Professional level exam bearing a 642 prefix.Does this mean i have to CLEAR all the CCNP papers with the prefix 642 or it would be OK if i clear ONE paper of the 4 papers.
3. If i clear ONE paper say BCMSN will i be successful to retain the active CCNA status.If the answer is YES ,how long can i retain this active status?
Hope everything is clear and i request you to answer all the above questions..
Thanks in advance and for your time.
Syed
Collin Clark Thu, 03/19/2009 - 06:43
You only need to take 1 CCNP level exam to re-certify your CCNA. It will be valid for another 2 years.
Hope that helps.
ross_rulz Thu, 03/19/2009 - 20:28
In response to the above comment it will be valid for another 3 years not 2.
Ross.
muzeeb7398 Fri, 03/20/2009 - 08:24
Mr.Clark thanks alot for the swift reply.As i understand i need to Pass ONLY ONE of the 4 papers for re-certifying my ccna?Am i right?
Are you sure that its valid for 2 years?
Thanks in advance.
Syed
muzeeb7398 Fri, 03/20/2009 - 08:26
Hi Ross,
Thanks for the correction but do u have a link which supports ur statement
