LMS 3.1 DCR export - management IP address.
pvignaud
If I export the DCR (Common Services + Device and Credentials + Device Device Management + export) in a file (csv); the output is sometimes (for some devices) without an "ip management address".
The devices has an IP address and "Device Center" show me this address, but the DCR v3.0 doesn't show me this, why ?
Exemple :
,node1,,,node1,1.3.6.1.4.1.9.1.576,0,279120799,dksok,sjdsk,,,,,,,,,,,,,,,,,,,,,,
10.6.95.250,node2,,,node2,UNKNOWN,,UNKNOWN,dksldk,,,,,,,,,,,,,,,,,,,,,,,
Thanks.
Patrick.
akemp
Level 5
Level 5
Thats strange, the first field is the management IP address. I'm assuming that you added the device by hostname ? Ciscoworks has a hunt order in which it determines what the management address.
