Blocking 8010 port servers communication
Mar 19th, 2009
Hi.
How can I block the communication between two servers on port 8010 on a 4506 switch?. I can do it for access lists?
Thanks in advance,
[email protected]
rmarulandazapata Thu, 03/19/2009 - 11:34
Thank you very much Jon.
then for my case the setup would be:
Switch(config)# ip access-list extended 8010
Switch(config-ext-nacl)# permit udp host x.x.x.x host x.x.x.x eq 8010
Switch(config-ext-nacl)# exit
Next, create a VLAN access map named map2 so that traffic that matches the http access list is dropped and all other IP traffic is forwarded, as follows:
Switch(config)# vlan access-map map2 10
Switch(config-access-map)# match ip address 8010
Switch(config-access-map)# action drop
Switch(config-access-map)# exit
Switch(config)# ip access-list extended match_all
Switch(config-ext-nacl)# permit ip any any
Switch(config)# vlan access-map map2 20
Switch(config-access-map)# match ip address match_all
Switch(config-access-map)# action forward
Then, apply the VLAN access map named map2 to VLAN 1, as follows:
Switch(config)# vlan filter map2 vlan 1
This would block traffic to this port in both directions?
Thanks again,
[email protected]
