Cisco 851 Router
Mar 19th, 2009
I cant seem to console into a Cisco 851 router. I pull up hyperterminal and cannot get connection via console cable.
9600 baud
8 data bits
no parity
1 stop bits
no flow control
I do this all the time but cannot get any output from router. Everything is up and running but I just need to get into this router.
Anyone have any ideas?
Giuseppe Larosa Thu, 03/19/2009 - 09:58
Hello Sparky,
you need to try with all possible speeds up to 115200 bps
There is a chance that the console speed has been changed.
Also check and verify the console cable with another device.
Hope to help
Paolo Bevilacqua Thu, 03/19/2009 - 10:41
Try another PC. I've seen 851s being picky about what and what not they like to use as console.
Bela Mareczky Thu, 03/19/2009 - 14:44
Try another console cable and hyperterminal software, check the COM port parameters. The Cisco standard console connection parameters are:
9600/ 8 N 1
I recommend PuTTY as a free and reliable alternative hyperterminal application.
An idea: I think You can check the successful boot of the C851 router: power on the router, wait some minutes and connect a PC to one of the switchport. Open Ethereal software and start a capture on the ethernet interface. You should see CDP packets sent out sourced from the router.
Hope this helps!
cisconoobie Tue, 03/24/2009 - 15:59
I tried all different baud rates and different settings. I'm using a Belkin usb to rollover cable adapter on my laptop. I have no problem conencting this to an asa but this 851 is just not responding.
I will try to cycle the power and see if I see anything different.
Is there any security setting that can prevent connectivity to the console port?
