remote logging(syslog information)
Mar 19th, 2009
Hi All,
Need to perform remote logging for the 6500 switch. Can you please suggests some syslog server software which will be installed on the public ip server (windows) and will perform the logging(syslog).
Thank you,
Overall Rating: 5 (2 ratings)
sivaprakasam81 Thu, 03/19/2009 - 10:50
Can i installed it on webserver (public server) and get stored information from the remote server/device/router?
Giuseppe Larosa Thu, 03/19/2009 - 11:05
Hello ,
it should be possible the most used resource is disk. If only few devices are to be logged (be aware that firewalls are very verbose in their logs)
the syslog messages are sent inside UDP packets. (no retransmission)
You may need to tune QoS to provide BW for this type of traffic
if you think to send the packets over the internet I would suggest to use a pair of devices to build an ipsec tunnel for privacy.
Hope to help
