Site Survey Software Question
Mar 19th, 2009
I've inhereted a Wireless network with about 30 Aironet APs. We were looking into the Airmagnet Software, but have heard mixed reviews. Does anyone use this software or recommend something else?
I appreciate any help given!
Leo Laohoo Thu, 03/19/2009 - 19:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I'm using it. In my humble opinion, this software is worth it's cost.
terminalvelocity777 Sat, 04/11/2009 - 02:11
We use Ekahau and it seems to be up to the job.
We looked at motorola lanplanner and the wireless survey part of it but it was really expensive and really complicated.
Mick
Scott Fella Sat, 04/11/2009 - 05:04
  • Hall of Fame,
    2017 Wireless
We use the AirMagnet suite as our tools for surveying and troubleshooting. I know the others work also like Ekahau and Motorola. You just have to learn the right way to use the tools in order to get correct data. The only thing I don't like about AirMagnet is the fact that some versions seem to work better than others. depending on the laptop and build, you might get slightly different readings.
George Stefanick Sat, 04/11/2009 - 18:40
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Always make sure whatever card you use you test before you survey with. Ive had issues with cards reporting a higher than normal noise floor skuing the data collected.
