Message Notificaton for Unity 4.2(3)
Answered Question
Mar 19th, 2009
Greetings,
I have configured a subscriber to receive text message notifications on his cell phone when he receives a voicemail on Unity. I have configured the "Text Pager 1" option using his 10-digit phone number, ending in "@vtext.com" I have made sure it is "Enabled" and that the "Only if Urgent" option is not checked. However when he receives a voicemail, he does not receive a text on his phone. I have other subscribers configured exactly the same as this particular one, and the notifications work just fine for them. I have plenty of available ports configured to send notifications. Our Unity system is stand-alone and not integrated with our company's AD. I haven't seen anything yet on the port status monitor, but I am wondering if anyone has any suggestions. Thanks.
Correct Answer by Bradford Magnani about 8 years 1 week ago
Mike,
Do you see the notifications with similar @domain name syntax being dialed out of Port Status Monitor for the working users? These should be sent just as normal emails would be sent, directly to the mailstore which handles the delivery to the provider, who then sends the text to the phone. You may want to verify on the mailstore with message tracking that the message isn't getting hung up anywhere for delivery.
Hope that helps,
Brad
Overall Rating: 5 (1 ratings)
Correct Answer
Bradford Magnani Thu, 03/19/2009 - 11:41
  • Cisco Employee,
Mike,
Hope that helps,
Brad
Christopher McAlpin Thu, 03/19/2009 - 12:08
  • Cisco Employee,
Brad is correct in that these notifications will not be seen on the port status monitor as Cisco Unity does not place a phone call to deliver SMTP notifications. The notification is sent as an email, therefore is simply handed off to the Exchange/Domino server for delivery.
Check that the notification device "Text Pager" is actually enabled and that the schedule is set appropriately.
mikechristensen Thu, 03/19/2009 - 12:21
Hey Brad,
No, I didn't see the domain syntax being dialed out of the Port Status Monitor. However, using your message tracking suggestion, I was able to determine that the message was being sent from Unity. Turns out that the user had two separate and valid contact objects, so it was not able to resolve properly and the message was simply dropped. We deleted one of the contacts and what do ya know? :) It works! Thanks for your help!
