Question about portOperStatus.2.1 output
laamidd2003
MIB CISCO-STACK-MIB
Name portOperStatus.2.1
iso.org.dod.internet.private.enterprises.cisco.workgroup.ciscoStackMIB.portGrp.portTable.portEntry.portOperStatus.2.1
OID 1.3.6.1.4.1.9.5.1.4.1.1.6.2.1
Type INTEGER
Units
Access read-only
Status unknown
Value minorFault(3)
The current operational status of the port.
Possible Values :
down(-1)
other(1)
ok(2)
minorFault(3)
majorFault(4)
fullDuplex-10Mb(5)
fullDuplex-100Mb(6)
autoNego-failed(7)
halfDuplex-1000Mb(8)
fullDuplex-1000Mb(9)
Obviously some of these possible values are self explanatory.
But, what is a minor fault vs. a major fault?
Does ok mean everything is fine?
What does "other" mean?
Bob
Joe Clarke
A state of minorFault is not good. Check portAdditionalOperStatus for more of a clue as to why that may be.
Other could mean anything, really. It usually points to a gap between device and MIB instrumentation.
Ok, thanks.
On our 6513 Catalyst - IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
portAdditionalOperStatus shows as an "unsupported OID"
This object is typically a CatOS object. You can try running "show int status" on the switch to see if that command gives you more specific details as to the real state of the port.
