ASA 5505 Port Forwarding
I am having simple issue with setting up port forwarding for RDC on ASA 5505. I have configured several other ASA 5505 appliances using the same commands and they all work fine. Here is the running config. Any help would be appreciated.
Result of the command: "show conf"
: Saved
: Written by enable_15 at 05:11:58.270 UTC Thu Mar 19 2009
ASA Version 7.2(2)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxxx encrypted
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address 70.x.x.x
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxxx encrypted
ftp mode passive
dns server-group DefaultDNS
access-list outside_access_in_web extended permit tcp any interface outside eq 3389
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1
static (inside,outside) tcp interface 3389 3389 netmask
access-group outside_access_in_web in interface outside
route outside 70.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
robertson.michael Thu, 03/19/2009 - 12:48
Hi Almir,
Your ACL and NAT statements both look good to me. Try adding:
ASA(config)# interface e0/x
ASA(config-if)# switchport access vlan 1
Where e0/x is the interface that the RDP server ( is connected to (e.g. e0/1). This will configure the switch port as an access port for VLAN 1 (your inside network).
Hope that helps.
ex_pmadayag Mon, 03/23/2009 - 10:05
config looks fine
Does RDP work locally?
If you access the rdp server from outside, do you get hit counts in your outside ACL?
