Setting up a modem to dial into on the AUX port has been a nightmare. I have the following configured on R1:
line aux 0
password cisco
login
modem inout
speed 115200
flowcontrol hardware
transport input all
modem auto configure type default
I then have to reverse telnet to the modem, this being necessary for a remote dialin to connect to the aux port. However, when I dialin from a remote pc using the normal Microsoft dial-up connection, I get a black window with a blinking prompt but I'm unable to type in window. If I enter a command in the window, I can see it being entered into the modem of the AUX port. If I click the button called DONE on this screen, it gets stuck on "verifying username and password". The reverse consol session then shoots out garbage characters and connection drops.
All I want is a simple out-of-band dialin to connect to a remote router. I have spent 2 valuable days on this and gone through all documentation. Is it my dial-up connection or the modem (the modem is a standard 56k V.92/V.90 with NO dip switches only software switches). The only AT command I've used is the at&f1s0=1 I simply cannot get hold of a USRobotics modem in this country. I have tried connecting at 9600 but that doesn't work.
Help please
Marcus
