03-19-2009 12:44 PM - edited 03-06-2019 04:42 AM
My supervisor blades have 2 10GE ports and 4 GE ports on them. I have 2 supervisor blades on my 4510. I was wondering if I can use all 8 (4 on 1st blade and 4 on the 2nd blade) at the same time. I do not plan on using the 10GE ports.
Solved! Go to Solution.
03-19-2009 12:54 PM
Unfortunately I don't believe that will work. You will only be able to use 2 1G SFP's per supervisors giving you a total of four.
When two Supervisor Engine V-10GEs are present in a Catalyst 4510R or Catalyst 4507R switch, two SFP uplinks are active on both the primary (active) and secondary (standby) supervisor engines by default, or four uplinks will be active in a nonredundant configuration.
HTH,
Mark
03-19-2009 12:54 PM
HTH,
Mark
03-19-2009 01:55 PM
So, I would need to add an SFP blade (such as a WS-X4506-GB-T)in order to get more GIG interfaces? Correct?
03-19-2009 02:07 PM
Brian,
That is correct. You would need an additional blade to satisfy your requirement.
HTH,
Mark
03-19-2009 02:09 PM
Thanks Mark!!!
03-19-2009 02:11 PM
Are these blades Hot Swappable too???
03-19-2009 02:20 PM
Yes, They are hot swappable.
