Cisco Unity 4.1 message timestamps off by 1 hour DST patch already applied
uhl_frederick
Have Unity 4.1 where the message timestamps are off by one hour. The Windows 2000 server has the DST patch appplie, and the time is correct. In the Unity port-status page, the time in the logs is correct too. It is when a voicemail is left that the timestamp is off.
Thanks in advance,
Gene
Brandon Buffin
Gene,
Check the time, timezone, DST patch on the mail server.
Brandon
Thanks for the reply. The Message in Outlook via Exchange 2003 has the correct time on it. The Unity server using MS TZ utility shows the time zone is correct and it is set for the correct DST. The time on Exchange is also correct. It is only when you check your VM via the phone that it is one hour behind.
GEne
