Paolo Bevilacqua Thu, 03/19/2009 - 13:30
How exactly you connected the two systems? Do you mean you're not seeing the calling name ?
Kenneth Mohammed Thu, 03/19/2009 - 14:11
Do you have it configured as intercluster trunk, or is the CME router configred as H323 gateway in CCM? And are you referring to the corporate directory?
wrayandnephew Thu, 03/19/2009 - 15:03
Yes I do not receive display names. If you could me some pointers or point me to an article I will implement it
wrayandnephew Fri, 03/20/2009 - 06:47
Yes. I cannot see the calling name.
I want users from the CME to see directory names of Call Manager 4.0 users when the phone rings
Kenneth Mohammed Fri, 03/20/2009 - 08:01
In the Call Manager, on the DN configuration page, set the alerting name to the name you would like displayed.
Hope that helped, if so please rate.
wrayandnephew Fri, 03/20/2009 - 08:09
It is already set . The problem is for CME users it does not show the name of the calling CUCM 4 user. CUCM4 users can see other CMCU 4 user names
chrisluven Fri, 03/20/2009 - 08:24
Try setting the "ASCII Alerting Name" and the "ASCII Display (Internal Caller ID)" on CUCM 4.
Chris
wrayandnephew Mon, 03/23/2009 - 11:05
Issue has been resolved. I checked the IE option in the H.323 gateway connection to the CME. Thanks Guys
