OSPF - route issue
Mar 19th, 2009
I have a weird situation,
There is a Webserver located on Site-Y, when users on Site-X try to access it ; the traffic goes
via VPN Tunnel (( site A )) and returns back same path.
I wanted all traffic for Site-Y initiating from Site-X should go via FR_RTR
How could I resolve it...
Attached is network diagram and config of Site-X and Site-Y
Joseph W. Doherty Thu, 03/19/2009 - 16:22
You haven't posted enough information to be certain (e.g. VPN routers configs), but its likely if you're running OSPF both via frame-relay and via VPN, the VPN paths OSPF cost is less or the cost is the same. (If the cost is the same, traffic should normally alternate paths.)
ronald.ramzy Thu, 03/19/2009 - 16:49
Thanks for your reply.
I didnt get what you mean, my requirement is that "Traffic for site-Y initiated from Site-X should be via FR-RTR and traffic for Site-A initiated from Site-x should go via VPN Tunnel...
Plz help
Joseph W. Doherty Thu, 03/19/2009 - 17:47
Yes I understand, but you did not post enough information to be certain what the issue is. From what you did post, I suspect Site-X sees reaching Site-Y is "better" going via Site-A, and the same for the converse.
Giuseppe Larosa Fri, 03/20/2009 - 01:19
  • Hall of Fame,
    Founding Member
Hello Ronald,
Joseph is right we can only guess that the OSPF best path is via the vpn tunnel.
take two subnets as example and provide
sh ip route X
sh ip route Y
there are chances that the path over the VPN sees only LAN interfaces, instead the FR path sees a low bandwidth serial interface and so the cost via FR is higher.
How is the VPN made ? Are you using a GRE tunnel protected by IPSec ?
using sh ip ospf interface of all involved interfaces you can find a confirmation to our guess.
Another possible reason is a comparison between different types of OSPF routes
Hope to help
Giuseppe
ronald.ramzy Fri, 03/20/2009 - 05:27
Thank to all for your reply.
Yes we have GRE tunnel protected by IPSEC
when I do sh ip route 192.168.99.0 it goes via GRE-tunnel rather than FR_RTR
Frame_Relay connection is 1MB
GRE_IPSEC Tunnel is 2MB to site_A
From Site_Y GreIPSEC tunnel is 2MB to Site_A
Is it a good idea to run EIGRP for FRame_relay Router and OSPF with GRE_IPSEC...
can someone help with sample configuration on cisco_doc_link
Giuseppe Larosa Fri, 03/20/2009 - 05:39
  • Hall of Fame,
    Founding Member
Hello Ronald,
the FR path is less preferred for its lower bandwidth.
If you want to move only part of traffic you can use PBR to send some traffic over the FR link.
if you use EIGRP over the FR link all traffic will go via the FR link for the lower administrative distance.
I think you can achieve some load sharing using PBR
see
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_prb_mult_track_ps6922_TSD_Products_Configuration_Guide_Chapter.html
the idea is to configure a route-map that invokes ACLs to define traffic to be redirected.
Hope to help
Giuseppe
rpfinneran Sun, 03/22/2009 - 04:56
  • Bronze, 100 points or more
You could tweak the OSPF cost of the FR cloud to make it the preferred route from X to Y. However, you may also have to tweak costs of GRE tunnels to site A to ensure that traffic from A to Y still uses the GRE.
If you provide the reference bandwidth being used in OSPF process then I could provide a solution as described above. Default RBW is 100Mb.
ronald.ramzy Sun, 03/22/2009 - 23:03
GRE Tunnel = 2MB
FR=1MB
I hope this is the informtaion you needed.
Plz can u provide the solution as u explained
rpfinneran Mon, 03/23/2009 - 04:30
Currently the cost from Site X to Site Y via FR cloud is 100 (assuming your using default reference bandwidth). The cost from Site X to Site A would be 50. The cost from Site A to Site Y would also be 50. So, you can see, there is actually equal path costs from X to Y right now. By default your traffic should be load balanced per flow (based on source/destination IP address). If from your Core device at Site X you issue a "show ip route y.y.y.y" for some network at Y, there should be two valid equal path routes. Do you get that?
If so, the following changes will correct this and allow Site X traffic to use the FR cloud as the primary route to Site Y, but failover to use the VPN should the FR cloud go down.
Site X FR-RTR
conf t
interface Serial0/0/0.2 point-to-point
ip ospf cost 80
end
wr
Site Y FR-RTR
conf t
ip ospf cost 80
end
wr
ronald.ramzy Mon, 03/23/2009 - 11:30
Today Cisco System Engineer try to tackle the issue but no luck and recommended to have EIGRP running on Frame-relay cloud only and OSPF on LAN & GRE with IPSEC.
what do you suggest.
Giuseppe Larosa Mon, 03/23/2009 - 13:25
  • Hall of Fame,
    Founding Member
Hello Ronald,
using two different routing protocols that offer comparable routes (same prefix and same prefix len) build a primary and backup path:
EIGRP is preferred over OSPF and this is different from what you want.
I think you should try the suggestions from Ryan.
OSPF metric is simply the sum of individual costs so if all links are in the same Area for OSPF you should be able to move traffic as you like.
if the paths are in different OSPF areas however, the OSPF hierarchy makes O routes preferred to O IA routes regardless of metric.
Edit:
I've reviewed the attached configurations and all paths are in OSPF area 0 so tayloring the metrics is possible.
Randy has given you an example of the approach to be used.
the cost of the FR link has to be less then going twice through the GRE tunnels
Hope to help
Giuseppe
ronald.ramzy Tue, 03/24/2009 - 08:26
Thanks Giuseppe & Ryan
But after trying the cost still it doesnt seems to work.
rpfinneran Wed, 03/25/2009 - 03:48
Can you provide the routing tables of your core devices? At least the routing entries we are concerned with...I am sure we can solve this problem.
Ryan
ronald.ramzy Wed, 03/25/2009 - 13:10
I have already posted this earlier mate.
is there any other commands I am missing.
sdoremus33 Thu, 03/26/2009 - 22:28
Just as an example what if you set the following config on Frtr(x)
interface serial0/0/0.2 point-to-point
ip ospf cost 120
ctrl-z
end
and Frtr(y)
ip ospf cost 120
ctrl-z
end
This is just to see how these route metrics work in your scenario
ronald.ramzy Fri, 03/27/2009 - 02:05
Didnt help.
when I do sh ip route (Network-range) from Site X to Site-Y ; it still goes via vpn-tunnel
Result type of sh ip route is type intra area
when I do sh ip route (network-range) from Site(X) to Site(A) = Known via "ospf 1", distance 110, metric 10003, type intra area
when I do sh ip route (network-range) from Site(X) to Site(Y) = Known via "ospf 1", distance 110, metric 10402, type intra area
rpfinneran Sun, 03/29/2009 - 01:49
You need to post the routing tables, not just the configs.
Do "show ip route" on both core devices at X and Y. Also, issue same command on FR routers and VPN routers.
ronald.ramzy Sun, 03/29/2009 - 23:14
Thanks to all for the reply.
FR Service provider is moving all links to MPLS (BGP).
I will keep posted if any issue arises.
Thanks again to all
