OSPF debug pleads the Fifth
Mar 19th, 2009
  • Bronze, 100 points or more
I don't have a functional install of Wireshark (or of any other sniffer/pkt analyzer) yet, but I was still hoping the debug command(s) would tell me something.
Logged on to a non-ABR backbone router, I wanted to see a Type 3 LSA arrive. I had two routers up and running in Area 1 but they were not connected yet. My plan was to connect them via Ethernet (their segment address is 10.3.3.0/24) and then see the Type 3 LSA announcing this network arrive at Router G (which is in Area 0, connected via token ring to Router F, the ABR to Area 1).
Well the LSA arrived well and fine, as the outputs of two sh ip ospf data commands shows; but I had both lsa-gen and spf debugging on, and, as you can see from the same console output, no debug info appeared.
Should it have?
output:
NOW WE WILL SEE TYPE3 LSA'S ARRIVE FROM 222.1.6.1
% Invalid input detected at '^' marker.
Router-G#ADVERTISING NETWORK 10.3.3.0 FROM AREA 1
Router-G#debug ip ospf lsa-gen
OSPF summary lsa generation debugging is on
Router-G#debug ip ospf tree
OSPF database events debugging is on
Router-G#sh ip ospf data
OSPF Router with ID (222.1.7.1) (Process ID 100)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
222.1.6.1 222.1.6.1 1731 0x80000005 0x42D 2
222.1.7.1 222.1.7.1 1895 0x80000004 0x86A1 1
222.1.8.1 222.1.8.1 490 0x80000005 0x2307 2
Net Link States (Area 0)
10.4.4.8 222.1.8.1 1997 0x80000003 0x6B0E
Summary Net Link States (Area 0)
201.0.0.0 222.1.6.1 1513 0x80000002 0x2DE0
Router-G#sh debug
IP routing:
Router-G#SH IP OSPF DATA
222.1.6.1 222.1.6.1 1974 0x80000005 0x42D 2
222.1.7.1 222.1.7.1 94 0x80000005 0x84A2 1
222.1.8.1 222.1.8.1 734 0x80000005 0x2307 2
10.4.4.8 222.1.8.1 231 0x80000004 0x690F
10.3.3.0 222.1.6.1 147 0x80000003 0x9663
201.0.0.0 222.1.6.1 197 0x80000003 0xA8A4
Router-G#
Edison Ortiz Thu, 03/19/2009 - 16:56
  • Hall of Fame,
    Founding Member
debug ip ospf spf showed the output from a LSA Type 3
R1:
R1(config-router)#net 1.1.1.1 0.0.0.0 area 1
R2:
00:07:22: OSPF: Start processing Summary LSA 1.1.1.1, mask 255.255.255.255, adv 13.3.3.3, age 1, seq 0x80000001 (Area 0) type 3
00:07:22: OSPF: insert route list LS ID 1.1.1.1, type 3, adv rtr 13.3.3.3
HTH,
__
Edison.
