Problem for see accounting in ACS 4.1
Mar 19th, 2009
I have ACS 4.1 and i've configured aaa in a Router, my problem is that I can't see the accounting in ACS for example i want to know that has done the users for example if an user type show runn, conf ter, shutdown in the interface. actually my aaa configuration is:
How i can see the accounting?? in the acs?? in acs 3.3.3 I can see the accounting, but in this version nothing.
version 12.4
hostname Router_Lab
boot-start-marker
boot-end-marker
enable secret 5 $1$051s$Few6cFXNT6T0TdAZqHkNu.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default enable
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
resource policy
ip subnet-zero
ip cef
username admin password 0 cisco123
interface FastEthernet0/0
ip address 172.20.0.1 255.255.255.0
duplex full
speed 100
snmp-server community adexus123 RW
snmp-server host 172.20.0.100 adexus123
tacacs-server host 172.20.0.11 key cisco123
tacacs-server timeout 3
tacacs-server directed-request
my logs when I put show running-config
Router_Lab#
*Mar 19 18:42:59.599: AAA: parse name=tty2 idb type=-1 tty=-1
*Mar 19 18:42:59.599: AAA: name=tty2 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=2 channel=0
*Mar 19 18:42:59.603: AAA/MEMORY: create_user (0x654D1F28) user='adexus' ruser='Router_Lab' ds0=0 port='tty2' rem_addr='172.20.0.100' authen_type=ASCII service=NONE priv=15 initial_task_id='0', vrf= (id=0)
*Mar 19 18:42:59.607: tty2 AAA/AUTHOR/CMD(3705108292): Port='tty2' list='' service=CMD
*Mar 19 18:42:59.611: AAA/AUTHOR/CMD: tty2(3705108292) user='adexus'
*Mar 19 18:42:59.611: tty2 AAA/AUTHOR/CMD(3705108292): send AV service=shell
*Mar 19 18:42:59.615: tty2 AAA/AUTHOR/CMD(3705108292): send AV cmd=show
*Mar 19 18:42:59.615: tty2 AAA/AUTHOR/CMD(3705108292): send AV cmd-arg=running-config
*Mar 19 18:42:59.619: tty2 AAA/AUTHOR/CMD(3705108292): send AV cmd-arg=<cr>
*Mar 19 18:42:59.619: tty2 AAA/AUTHOR/CMD(3705108292): found list "default"
*Mar 19 18:42:59.623: tty2 AAA/AUTHOR/CMD(3705108292): Method=tacacs+ (tacacs+)
*Mar 19 18:42:59.627: AAA/AUTHOR/TAC+: (3705108292): user=adexus
*Mar 19 18:42:59.627: AAA/AUTHOR/TAC+: (3705108292): send AV service=shell
*Mar 19 18:42:59.627: AAA/AUTHOR/TAC+: (3705108292): send AV cmd=show
*Mar 19 18:42:59.631: AAA/AUTHOR/TAC+: (3705108292): send AV cmd-arg=running-config
*Mar 19 18:42:59.631: AAA/AUTHOR/TAC+: (3705108292): send AV cmd-arg=<cr>
*Mar 19 18:42:59.875: AAA/AUTHOR (3705108292): Post authorization status = PASS_ADD
*Mar 19 18:42:59.875: AAA/MEMORY: free_user (0x654D1F28) user='adexus' ruser='Router_Lab' port='tty2' rem_addr='172.20.0.100' authen_type=ASCII service=NONE priv=15 vrf= (id=0)
Vinay Sharma Mon, 04/13/2009 - 10:25
Thanks for the info. Their is a know bug for command accounting in ACS v4.1 and it is fixed in cumulative patch 5. The patch is available at cisco.com. make sure you take the backup before applying the patch. CSCsg97429 TACACS+ Command Accounting does not work in ACS 4.1(1) Build 23.
sachinga.hcl Tue, 04/14/2009 - 10:55
Hi Vinashar,
This issue occurs due to the presence of Cisco bug ID CSCsg97429.
No accounting records appear in the Terminal Access Controller Access Control System (TACACS+) Administration log file.
The problem starts when command Accounting is configured on the Network Attached Storage (NAS). After commands are entered on the NAS, no records appear in the TACACS+ Administration log file.
Debugs on the NAS show the records are sent, and they do arrive at the ACS, but the appropriate log file fails to update.
With ACS logging set to Full in System Configuration > Service Control, the log file of the CSLog service shows these entries each time a command is entered on the NAS:
12/06/2006 14:22:52 U 5111 2608 Handling message at 0x010A7FF8 (339 bytes)
12/06/2006 14:22:52 A 0000 0960 Logger CSV TACACS+ Accounting: filter denies logging
Resolution For a workaround:
Download and install these patches from Cisco Downloads:
CiscoSecure ACS for Microsoft Windows
Acs_4.1.1.23.5-SW.zip?ACS 4.1.1.23.1 accumulative patch
