priviliege level
k.ramalingam
Hi Experts,
I'm trying to create privilige level 10 which allow show running-config and all other shows. I applied the below configs on the console of a cisco 2821 and it works. I can see the config by doing more system:running-confg but it fail to work on cisco 1803 router.
enable secret level 15 cisco
privilege exec level 15 configure
enable secret level 10 cisco123
privilege exec level 10 more
username cisco privilege 15 password cisco
username test priv 10 pass test
line console 0
login local
After applying the above on Cisco 1803, I'm still able to show commands, but when I do more system:running-configs, I only see 2 lines of the configs which are the boot system configs and thats all.
Please let me know if i'm missing anything.
Hi Kumar,
In some versions of IOS, a user will only be able to see commands in the running config that they are privileged to use. So, I believe that if you allow privilege level 10 to configure, for example, the 'access-list' command, all of your ACL statements would appear in the running config for the level 10 user.
Hope that helps.
-Mike
