QOS COS
Mar 19th, 2009
I want to make sure i have this correct:
lets say a 3560 switch here:
mls qos is enabled, nothing else.
packet comes in at cos 5.. it will get rewritten to 0. The reason it is 0 is because the mls qos cos 0 command which is default. If i change this command to mls qos cos 1 then all packets would be cos 1. Correct?
Adding to above scenario. If i do mls qos trust cos.. all cos packets coming in at 5 will remain at 5. All packets coming in unmarked will get changed to cos 1. Is this correct?
Building on that. If i now do mls qos override. ALL Packets will get changed to cos 1.
Am i wrong in any of my above understanding?
Jon Marshall Wed, 03/25/2009 - 17:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mike
"The reason it is 0 is because the mls qos cos 0 command which is default"
Correct.
"If i change this command to mls qos cos 1 then all packets would be cos 1"
Yes, correct again. By using this command you have changed default value of a port to be Cos 1. So any untagged packets will have their value set to Cos 1.
"Building on that. If i now do mls qos override. ALL Packets will get changed to cos 1"
Yes, correct again.
Your understanding is spot on.
Jon
greg.loria Tue, 04/21/2009 - 01:45
Hi Jon, are these the same with dscp?
We are having trouble with our present setup:
We have two 4500 switches, A and B that are connected by a trunk link. The packet leaves Switch A with a mark of QoS 5 but the value returns to default after passing through the link. Why do you think this issue occurs even though qos trust dscp is configured?
Thanks.
