Can I do load-sharing on the ASA when using Site-to-Site VPN?
Mar 19th, 2009
  • Gold, 750 points or more
I'm using ASA as a VPN concentrator on HQ site. I've used Public IP addresses on both interfaces,Inside and Outside interfaces. I've had 4 branch sites connecting to HQ using Site-to-Site VPN. How can I do load-sharing with those 2 interfaces on ASA? What I want to do is that 2 branch sites peer with the outside interface and the other 2 branch sites peer with the inside interface. Is this possible? If not,What's the best practice to do?
TIA
Toshi
Overall Rating: 4 (1 ratings)
thotsaphon Fri, 03/20/2009 - 11:42
Hi Andrew,
Thanks for the prompt. What I'm going to do at HQ site is as follows:
- I've got 2 WANs (2 ISPs)
- I've got a load balance box.
- I've got 2 Public IP Blocks from 2 ISPs
ASA-->Default Route--> LoadBalanceBox--> Separate 2 Wans(2 ISPs)
Outside(Untrust) interface will be assigned with the public ip address of ISP-A.
Inside(Trust) interface will be assigned with the public ip address of ISP-B.
I've got 4 branch sites to do site-to-site VPN with HQ site.
I want the 2 branch sites to peer with the outside interface on the ASA (Via ISP-A).
I want the other 2 branch sites to peer with the inside interface on the ASA (Via ISP-B). But traffic will go from outside-to-inside. Is this allowed by ASA?
Hopes I explained a bit more about my question in detail.
Please share what you guys think.
TIA
Toshi
thotsaphon Fri, 03/20/2009 - 12:26
Hi Andrew,
That's why I called "Load-Sharing". I want to use 2 ISPs for peering IPSec VPN. Actually I can do NAT(udp/500,4500) on the device connecting to the ISP-A to terminate IPSec packet on the outside interface as the packets coming from the ISP-B. I just want to know that ASA allows us to do IPsec peer with the inside interface but packets coming from the outside interface or not.
Toshi
JamesLuther Fri, 03/20/2009 - 12:28
  • Silver, 250 points or more
Hi Toshi,
This isn't how I would implement.
It sounds like you have two Provider Allocated (PA) IP ranges and therefore you require two interfaces with public IPs. However I would configure two outside interfaces and IP your inside interface using private addressing. ie
interface Ethernet0
nameif ISP1
security-level 0
200.1.1.1
interface Ethernet1
nameif ISP2
security-level 0
195.1.1.1
interface Ethernet4
nameif inside
security-level 100
ip address 192.168.1.1
VPN traffic will be allowed to go from outside to inside if it's defined in the crypto ACL.
There are also lots of other designs you could do ie with a layer of routers and NAT or multi context mode ASA.
James
thotsaphon Fri, 03/20/2009 - 12:34
Hi James,
Thanks for that. The inside interface is connecting to all hosts assigned with the public ip addresses of ISP-A. This is the existing network. That's why I can't do 2 outside interfaces on the ASA
Toshi
thotsaphon Fri, 03/20/2009 - 13:40
Andrew,
Don't get me wrong. I indeed have 2 interfaces,Outside and Inside. They both have been assigned with the different public ip addresses from the different ISPs. My question is "Does ASA allow us to use the inside interface to do IPSec peer with the other devices comming from the outside interface?".
Toshi
In theory - yes.
It would be alot easier though if you connected the outside interface to a switch - and a port that was a trunk.
They you could create sub-interfaces of the outside interface, and give them the same security level - while allowing you to use the inside interface for management.
