access-list
Answered Question
Mar 19th, 2009
  • Bronze, 100 points or more
Hi everybody1
My book shows :
access-list 101 remark list to allow traffic from server1
Can i use named access list as;
ip access-list standard zee remark this is good traffic.?
thanks a lot!
Correct Answer by glen.grant about 8 years 1 month ago
Really named and numbered are handled the same now in my experience. Any code after 12.2.T . For instance if you do have the following
access-list 101 permit ip 10.1.1.0 0.0.0.255 172.16.1.0 0.0.0.255
You can then modify this as a named ACL
conf t
ip access-list extended 101
(This puts you acl config mode and you can add or delete stuff as any normal acl) and add as many remarks as you want in the ACL .
permit ip 10.1.2.0 0.0.0.255 172.16.1.10 0.0.0.255
remark Internet traffic
Correct Answer by Giuseppe Larosa about 8 years 1 month ago
hello Sarah,
to be noted that multiple remarks can be inserted in the ACL statements.
I once thought this is possible only with named ACL.
Hope to help
Giuseppe
Correct Answer by bmcginn about 8 years 1 month ago
Yes you can.
As pkurdziel mentioned above..
syntax to enter the config section for the ACL is:
ip access-list {standard|extended} [name of list]
!you can now put in your remark
remark This is my Named ACL
!follow it on with the statements
permit ip any any
Overall Rating: 5 (4 ratings)
pkurdziel Thu, 03/19/2009 - 21:01
This is the commented name IP ACL command syntax.
ip access-list {standard|extended} name
remark remark
This is the commented numbered IP ACL command syntax.
access-list access-list-number remark remark
sarahr202 Thu, 03/19/2009 - 22:09
Thans a lot. HOw about named access list? Can we use " remark" option with it?
thanks a lot!
Correct Answer
bmcginn Thu, 03/19/2009 - 23:15
Yes you can.
permit ip any any
Correct Answer
Giuseppe Larosa Fri, 03/20/2009 - 01:08
  • Hall of Fame,
    Founding Member
hello Sarah,
Hope to help
Giuseppe
sarahr202 Fri, 03/20/2009 - 09:12
Thanks Giuseppe!
You lost me here. Could you please give any example?
Giuseppe Larosa Fri, 03/20/2009 - 15:00
  • Hall of Fame,
    Founding Member
Hello Sarah,
I was meaning that in different lines of an ACL more then one of them can be a remark command.
Hope to help
Giuseppe
Correct Answer
glen.grant Sat, 03/21/2009 - 05:19
  • Purple, 4500 points or more
conf t
