OSPF Load Balancing on ASA
Hi Andrew,
Sorry, I should have mentioned we are supplying 2 edge routers (which will sit between the ASA and our ISP) which our ISP will run BGP into on one side and then I we will redistribute those routes into OSPF on our side. The question is that given 2 equal costs routes & OSPF will an ASA load balance data between the 2 routers?
