IOS installation from xmodem
Mar 20th, 2009
I attempted re-installing the IOS image of my 3750 switch which was formatted in error. When I open hyperterminal, and select default setting (9600 baud etc etc), below is what I get.
Base ethernet MAC Address: 00:12:d9:95:db:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: filesystem check interrupted!
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
The system has been interrupted, or encountered an error
during initializion of the flash filesystem. The following
commands will initialize the flash filesystem, and finish
loading the operating system software:
switch: flash_init
flashfs[0]: 2 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 2560
flashfs[0]: Bytes available: 15996416
flashfs[0]: flashfs fsck took 7 seconds.
Setting console baud rate to 9600...
switch: load_helper
switch: copy xmodem: flash:c3750-ipservicesk9-mz.122-25.SEE2.bin
Begin the Xmodem or Xmodem-1K transfer now...
CCCCCCCCCCBB0BB0xmodem:: I/O error
Any ideas on what I am missing out to get this right.
John Blakley Fri, 03/20/2009 - 06:34
If it's not already off, try turning flow control off before connecting to the switch.
