03-20-2009 03:08 AM
I am logging ASA syslog messages and im filtering on "notifications" I have one access rule that I do not want to recive any syslog notifications messages from. I have dissabled logging on this paticular access rule but still recive syslog messages relating to it.
Here is my config -
logging enable
logging standby
logging emblem
logging trap notifications
logging asdm informational
logging host management x.x.x.x format emblem
logging permit-hostdown
access-list acl_out line 26 extended permit tcp object-group ExampleGroup any object-group ExampleTCPGroup log disable
Any ideas?
Tim
03-20-2009 03:17 AM
Tim
What you have posted indicates that this line is disabled. In that case I am very puzzled that it can generate any syslog messages.
I would suggest that you might try rewriting the line to remove the log option:
Give that a try and let us know how it works.
Rick
03-20-2009 05:52 AM
Hi Rick
I have tried what you have suggested with no luck.
I have tried disabling logging on other lines also and still get syslog messages logged.
Cheers
Tim
03-20-2009 08:04 AM
Tim
Perhaps we might find a more effective suggestion if you would post a more complete config. It might also be helpful if you would post an example of the message as it appears in syslog.
Rick
