Unity 4.0.5 with Domino 8.0.2 ?
Mar 20th, 2009
HI,
my customer has: Unity 4.0.5 integrated with Domino 6.5.5(DUC 1.2.2-Italian)
he'll migrate to Domino 8.0.2
Have I upgrade Unity 4.0.5 to Unity 7 ?
Are not there other solutions?
Thanks.
Jaime Valencia Fri, 03/20/2009 - 08:57
  • Cisco Employee,
  • Hall of Fame,
    2011
no, it's the same as with Exchange 2007, mandatory to have at least Unity 5.X or above for the integration.
if you plan to upgrade domino then you'll need to upgrade unity as well
java
if this helps, please rate
