CSM 3.2.2 e CSA not upgraded
Mar 20th, 2009
Hi, during the CSM upgrade from 3.2.1 to 3.2.2 the installer thinks we have a full version CSA agent and it don't upgrade it to the 5.2.0.263 CSM version.
We have the CSA 5.2.0.238, installed by CSM, not the full version.
How to ? Can I upgrade it manually from the CSM DVD ?
thanks
Anonymous (not verified) Thu, 03/26/2009 - 18:51
Before you can successfully upgrade to Security Manager 3.2.2 from a prior version of Security Manager (versions 3.1, 3.1.1, 3.2, or 3.2.1 only), you must make sure that the Security Manager database does not contain any pending data, in other words, data that has not been committed to the database. If the Security Manager database contains pending data, you must commit or discard all uncommitted changes, then back up your database before you perform the upgrade.
r.spiandorello Fri, 03/27/2009 - 02:27
The CSM has been upgraded successfully !
I talk about only the csa, not upgraded the the new version (5.2.0.263), from the installer.
The csa is the old versione (5.2.0.238) with the CSM 3.2.2 sp1
r.spiandorello Tue, 03/31/2009 - 05:52
Hi, how to start again only the csa upgrade from the 3.2.2 upgrade software ?
thank you
