Adding access points to 877W ISR
Mar 20th, 2009
I have a customer who has an existing 877W on his network. He wants to add an access point in another area that is not covered by the ISR's wireless capability. Can the access point be plugged into the ISR and connect into the existing vlan's/ssid's or is it not possible because there are no layer 3 ports? He has the same scenario at another site but here he is using an 1801W. Any advice or links to configs etc much appreciated.
jeff.kish Fri, 03/20/2009 - 07:22
  • Silver, 250 points or more
He wants to plug an AP directly into the router? That's fine to do as long as you configure subinterfaces on your FastEthernet interface for trunking.
Does his router have a switch connecting to it? If so it would make more sense to plug the AP into the switch.
Example config:
int fa0/0
no ip address
int fa0/0.1
encapsulation dot1q 1 native
ip address x.x.x.x m.m.m.m
int fa0/0.2
encapsulation dot1q 2
int fa0/0.3
encapsulation dot1q 3
int fa0/0.4
encapsulation dot1q 4
Something like that.
mbluemel Fri, 03/20/2009 - 07:51
I think you misunderstand possibly Jeff. The ports on the 877 are layer 2 so you cannot use subinterfaces. Its a question really of trunking between the AP and the 877 without actually having a layer 3 interface.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
