WPA with local MAC address authentication
Mar 20th, 2009
Can Cisco Aironet AP support WPA encryptions with local MAC address authentications as the current setup i have do not have a radius server to authenticate my users.
i tried configuring with local MAC address but no success.
Overall Rating: 5 (1 ratings)
jeff.kish Fri, 03/20/2009 - 07:28
  • Silver, 250 points or more
Try this:
conf t
access-list 700 deny xxxx.xxxx.xxxx 0000.0000.0000
access-list 700 permit 0000.0000.0000 ffff.ffff.ffff
dot11 association mac-list 700
Replace the xxxx.xxxx.xxxx with each host you want to allow on the AP. This will block any other MACs from accessing the AP. This is not by SSID, this is by AP, so let me know if this will work for you.
day28lite Sat, 03/21/2009 - 07:24
what if i want by SSID ?
I have added the MAC address to the local MAC address pool at Advanced Security but when i tied it to my SSID, all users get thrown out.
Can local MAC address authentication work without radius server on WPA ?
gamccall Tue, 04/14/2009 - 09:42
What you're trying to do is exactly what RADIUS was designed for. Your best bet will be to just set up a RADIUS server and configure whatever filters you need.
jeff.kish Tue, 04/14/2009 - 10:41
And let me apologize for not realizing that you had responded to my post. Thanks gamccall for responding when I didn't!
