QoS Selectors
Mar 20th, 2009
  • Purple, 4500 points or more
All,
I have a router with a basic policy-map:
policy-map VOIP
class VOIP
priority 768
class class-default
fair-queue
random-detect dscp-based
cs6 71855/4018548 0/0 0/0 32 40 1/10
When I do a "sh policy-map inter s0/0", I get matches on CS6 under the class-default. If I'm not marking the packet, is the device? Is this where remarking comes in if I want to change what it wants to report?
I think this is a video camera that has an embedded web server. I've been fighting with voip phones at this location, and this video system has traffic pegged at 100% when they're connected to it with high resolution. I haven't been able to convince anyone at the location to use low res yet. If I want to control the amount of traffic going from that device, should I shape that traffic or police it? The phones will stay the same at 768k, and this is on a T1 P2P circuit.
John
Overall Rating: 5 (7 ratings)
Jon Marshall Fri, 03/20/2009 - 06:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
CS6 is used by Cisco devices themselves for certain priority traffic so that is what you are probably seeing altho it could be traffic you want prioritized - difficult to say.
Is the video traffic from the phone traffic ?. If so shaping would probably be the preferred option altho bear in mind some latency sensitive traffic does not like shaping.
Jon
John Blakley Fri, 03/20/2009 - 06:57
The video is from a security camera on T1 Side A. A user on the T1 Side B, connects to the camera using special software (which is really web-base) and stays in it all day. I've asked the IT contact at that location to make sure that everyone is in low res because that user brings down their packetshaper when they're connected to it. This also destroys the phone quality in Side A.
Personally, the phone quality is more important to me than them being able to connect to the security camera and stay in it in high res all day long, but I'm not sure about the best way to fix it.
Thanks Jon,
John
Joseph W. Doherty Fri, 03/20/2009 - 07:45
re: Phone quality
The video stream shouldn't impact your VoIP. Two items to check: 1) how's your voice signally being QoS'ed?, 2) what's the size of the hardware FIFO buffer?
re: video stream vs. non-VoIP
I would recommend you provide the video stream it's own dedicated class. You could shape or police it then, but perhaps just provide it a minimal bandwidth guarantee. This way you can say you're not doing anything to impede it, but if it has poor performance, there's just not enough bandwidth to support it (although there might be for a lower res stream). (NB: placing the video into a separate class might fix your voice issue.)
e.g.
policy-map VOIP
class VOIP
priority 768
class SecCam
!you'll need to define the class-map
bandwidth percent 1
class class-default
fair-queue
PS:
I would also recommend against using random-detect in class-default (for two reasons).
John Blakley Fri, 03/20/2009 - 07:49
Joseph,
"what's the size of the hardware FIFO buffer"
How can I find this out, and what's the recommended size? Also, is there a stipulation with FIFO size vs. available memory, i.e. 75% of Available memory is the max a FIFO buffer can be.
Why would you recommend the random-detect be taken out of class-default? Do you think that could be causing some of the issue?
Thanks!
John
Joseph W. Doherty Fri, 03/20/2009 - 09:11
"How can I find this out, and what's the recommended size?"
I recall the setting can be seen with a show controllers command. (NB: For typical T1, it probably already defaulted to a small value, but can often be adjust with tx-ring-limit. For VoIP, you sometimes want to decrease the value.)
"Why would you recommend the random-detect be taken out of class-default"
Two reasons:
1) It really intended just for TCP
2) Since WFQ is active, I prefer to allow individual flow queue drops - WRED is more oriented for FIFO
"Do you think that could be causing some of the issue? "
Yes, but removing it alone, may not fix the issue. (It might, since you have lots of WRED drops shown in your another post.)
[edit]
Always hard to read the compressed whitespace posts. You may have many less drops then I thought.
[edit2]
Ah, only 78 total.
Joseph W. Doherty Fri, 03/20/2009 - 10:46
If the above doesn't correct the issue, also try "tx-ring-limit 2" on your serial interface.
If the issue still exists, let us know.
PS:
If you prefer, you can also use the minimum absolute bandwidth value for the SecCam class (8?).
Edison Ortiz Fri, 03/20/2009 - 07:54
  • Hall of Fame,
    Founding Member
Hi John,
As Jon stated CS6 is used for routing protocols in Cisco IOS and I don't recommend having any other traffic using that marking.
It seems the appliance you are using, it uses that QoS marking and the switchport where is connected to is simply passing the marking all the way to the router.
I remember you have Dell switches (we need to get you some Cisco switches in there :)) so we can't help much on it but you can remark the traffic incoming on the router with a MQC matching on the src-ip/src-port and apply a police (not to limit but to remark that traffic).
For instance(from the top of my head, don't have any equipment at the moment):
ip access-list extended Video-Camera
permit [video-camera ip and src port]
class-map Video-Camera
match ip access-group name Video-Camera
policy-map Inbound-MQC
class Video-Camera
police 8000 1000 conform-action set dscp AF31 exceed-action set dscp AF31
class class-default
Then, outbound you need to determine what to do with the traffic. I say go for shaping but I don't know the nature of the traffic and if shaping can create problems but at least, you've taken that kind of traffic out of CS6 and place into AF31.
HTH,
__
Edison.
John Blakley Fri, 03/20/2009 - 08:04
Thanks Edison. That makes sense.
The policy on side A (video camera side) is applied outbound, and the policy on side b (user side) is applied outbound as well. If I'm shaping on side a, do I need to do anything on side b for inbound?
John
Edison Ortiz Fri, 03/20/2009 - 08:08
  • Hall of Fame,
    Founding Member
I'm assuming that's after you've remarked the traffic?
Yes, if you've decided to shape the traffic on side A, it will be controlled there.
Have you verified that shaping may be a solution? You can use bandwidth guarantee instead. I believe the reason the voice was being affected was due to having the marking on CS6.
Change the marking first before deploying shaping and see if the VoIP improves.
__
Edison.
John Blakley Fri, 03/20/2009 - 08:10
I'll attempt that and see what happens.
Thanks!
John
John Blakley Fri, 03/20/2009 - 08:08
Oh, and once again the math is throwing me:
is "police 8000...."
is 8000 equivalent to 8k of bandwidth?
Edison Ortiz Fri, 03/20/2009 - 08:10
  • Hall of Fame,
    Founding Member
Yes, but in this case, you aren't policing the traffic to 8kbps. You are remarking everything that matches the class to AF31.
__
Edison.
John Blakley Fri, 03/20/2009 - 08:12
So because I'm remarking, the police values (being that they're required) are arbitrary values that won't be used for dropping excessive traffic?
John
Edison Ortiz Fri, 03/20/2009 - 08:15
  • Hall of Fame,
    Founding Member
Correct, the transmit|exceed option on the police command are the key options on what to do with the traffic based on the [bandwidth value] assigned to the command itself.
If you noticed, in my transmit and exceed options, I'm not saying to drop the traffic. I'm instructing the router to forward it but to apply a marking of AF31.
Please be aware to check the syntax as I did the whole thing without any equipment.
__
Edison.
Edison Ortiz Fri, 03/20/2009 - 08:20
  • Hall of Fame,
    Founding Member
BTW, if policing confuses you there :) You can do the same with the following:
class Video-Camera
set dscp AF31
class class-default
This is a more straightforward approach :)
With the police command, you have the ability to remark traffic that meets the bandwidth requirement and remark traffic with another marking that exceeds the bandwidth. Pretty useful tool.
John Blakley Fri, 03/20/2009 - 08:47
I started thinking about this. Because I'm seeing traffic matching on the VoIP class, is all of my other default traffic that's coming through the switch being marked as CS6?
Serial0/0
Service-policy output: VOIP
Class-map: VOIP (match-any)
21716081 packets, 1988364582 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 110
21716080 packets, 1988364562 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 768 (kbps) Burst 19200 (Bytes)
(pkts matched/bytes matched) 1797007/175537353
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
22479678 packets, 16547729203 bytes
5 minute offered rate 5000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/78/0
exponential weight: 9
dscp Transmitted Random drop Tail drop Minimum Maximum Mark
pkts/bytes pkts/bytes pkts/bytes thresh thresh prob
af11 0/0 0/0 0/0 32 40 1/10
af12 0/0 0/0 0/0 28 40 1/10
af13 0/0 0/0 0/0 24 40 1/10
af21 0/0 0/0 0/0 32 40 1/10
af22 0/0 0/0 0/0 28 40 1/10
af23 0/0 0/0 0/0 24 40 1/10
af31 0/0 0/0 0/0 32 40 1/10
af32 0/0 0/0 0/0 28 40 1/10
af33 0/0 0/0 0/0 24 40 1/10
af41 0/0 0/0 0/0 32 40 1/10
af42 0/0 0/0 0/0 28 40 1/10
af43 0/0 0/0 0/0 24 40 1/10
cs1 0/0 0/0 0/0 22 40 1/10
cs2 0/0 0/0 0/0 24 40 1/10
cs3 0/0 0/0 0/0 26 40 1/10
cs4 0/0 0/0 0/0 28 40 1/10
cs5 0/0 0/0 0/0 30 40 1/10
cs6 72372/4055890 0/0 0/0 32 40 1/10
cs7 0/0 0/0 0/0 34 40 1/10
ef 0/0 0/0 0/0 36 40 1/10
rsvp 0/0 0/0 0/0 36 40 1/10
default 22407237/16543569726 78/106186 0/0 20 40 1/10
Also, I looked at the QoS mappings on the switch, and if I'm reading them right, it looks like CS6 is the same thing as DSCP 4 (I'm not sure though.)
Thanks!
John
Joseph W. Doherty Fri, 03/20/2009 - 09:19
"it looks like CS6 is the same thing as DSCP 4 (I'm not sure though.) "
No, they're different.
Edison Ortiz Fri, 03/20/2009 - 09:21
  • Hall of Fame,
    Founding Member
No, you have CS6 and other traffic:
__
CS6 = to DSCP 4? That mapping is bad. CS6 = Binary 110 000 = DSCP 48
John Blakley Fri, 03/20/2009 - 09:22
This is what the switch is showing me:
Dscp-queue map:
d1 : d2 0 1 2 3 4 5 6 7 8 9
0 : 01 01 01 01 01 01 01 01 01 01
1 : 01 01 01 01 01 01 02 02 02 02
2 : 02 02 02 02 02 02 02 02 02 02
3 : 02 02 03 03 03 03 03 03 03 03
4 : 03 03 03 03 03 03 03 03 04 04
5 : 04 04 04 04 04 04 04 04 04 04
6 : 04 04 04 04
Now you can see why I'm wondering what it's doing. This is the evil Dell switch :-)
John
Edison Ortiz Fri, 03/20/2009 - 09:31
  • Hall of Fame,
    Founding Member
That's a dscp to queue map and DSCP48 is placed in Queue 4 highlighted below:
Dscp-queue map:
6 : 04 04 04 04
Edit: Misread the map, it looks like a dscp-cos map while it was a dscp-queue map.
Do you have any other maps?
John Blakley Fri, 03/20/2009 - 09:53
So, I take it that the switch may not be causing my problem with marking the traffic incorrectly?
Oh, I see how to read this chart:
DSCP 48 is d1(4) -> d2(8)....
I found a dscp-dscp mutation map that looks like this, but the numbers that this chart showed when compared to the dscp mutation map would show that it's going to send a packet received on an ingress port as dscp 04 which doesn't look right. Maybe I'm looking at it in reverse, and it receives dscp48 and sends out as CoS4?
John
Edison Ortiz Fri, 03/20/2009 - 09:59
  • Hall of Fame,
    Founding Member
We would need to see the mapping for that before coming to that conclusion. It's a Dell switch :)
Joseph W. Doherty Fri, 03/20/2009 - 10:31
"Oh, I see how to read this chart:
DSCP 48 is d1(4) -> d2(8).... "
Correct.
"Maybe I'm looking at it in reverse, and it receives dscp48 and sends out as CoS4? "
Well, 1) map is labeled "Dscp-queue map:", 2) IEEE 802.1Q CoS values are 0..7; these are the reasons I believe "4" to be queue 4, not a CoS 4, but if you can find a manual for the device, it would likely indicate which.
John Blakley Fri, 03/20/2009 - 10:51
The only other map that I found was the cos-queue map:
Cos-queue map:
cos-qid
0 - 1
1 - 1
2 - 2
3 - 2
4 - 3
5 - 3
6 - 4
7 - 4
It looks like it *should* be going in queue 3, but I'm not sure how to tell what queue 3 is. All of the ports are to trust the dscp markings.
This is the only other map that I had. There's not much you can do with these switches.
John
Edison Ortiz Fri, 03/20/2009 - 10:58
  • Hall of Fame,
    Founding Member
Ok, fair enough. We are digressing here :)
The router is receiving CS6 and the switch isn't remarking the packet.
If you know the src-ip and src-port, create an ACL at the router - match that ACL on a class-map and remark it to AF31.
If you know how to remark packets in the Dell switch or have the ability to change the QoS config on the appliance itself - then that can be another option.
Right now, I can only help you how to do it at the router :)
__
Edison.
John Blakley Fri, 03/20/2009 - 11:00
I completely agree; I think we're beating a dead horse =)
I'm sure I'll have other questions about something else later, but for now we'll let this thread die. ;-)
Thanks!
John
Joseph W. Doherty Fri, 03/20/2009 - 09:37
It looks like Dell maps DSCP values into one of 4 queues. CS6 is(?) mapping into Q4, and if that's a priority queue (or gets most of the bandwidth), that could explain some of your problem but only if the switch port is congested or Dell is doing some kind of shaping.
John Blakley Fri, 03/20/2009 - 10:41
Oh, and I'm not crazy about these Dell switches just to let you know :)
