FTP port 21 open on Cisco routers
Mar 20th, 2009
I have the following issue on a Cisco 7201 Internet-facing router:
TCP port 21 is open all the time and nothing stops it from staying open. There is no service started which keeps this port open, there is also an inbound ACL, assigned on the outside interface which filters everything except SSH from particular outside addresses... TCP port 21 stays open no matter what I do, no matter if I explicitly deny all traffic to this port, Nmap finds it open. Furthermore I tried to open a raw session to this port and according to Wireshark the three-way handshake passed perfectly well, then I was able to send strings which the router successfuly indicated as received with ACK bit, etc.
show tcp brief does not show this activity, there is no process related to FTP which is started, there is an ACL which explicitly denyes any traffic from any source to TCP port 21...nothing helps. It stays open all the time.
One more thing...the exact same behaviour is observed on a Cisco 2811 Internet-facing router. Nothing helps here also.
I find this a disturbing issue, please help me with some ideas..
Thanks in advance!
BR,
Kamen
Overall Rating: 5 (1 ratings)
cisco24x7 Fri, 03/20/2009 - 12:26
  • Silver, 250 points or more
On the Internet-facing router, do this:
access-list 199 deny tcp any Internet_IP eq 21 log
access-list 199 deny tcp any any eq 21 log
access-list 199 permit ip any any log
interface F0/0 (assuming that this is your Internet facing interface):
ip access-group 199 in
Now use nmap or nessus to scan the system again and see if it says port 21 open. I will be it will be NOT be listening, something like this:
[root@LinuxES-lab2 tmp]# nmap -sS 192.168.15.248
Starting nmap V. 3.00 ( www.insecure.org/nmap/ )
Interesting ports on (192.168.15.248):
(The 1596 ports scanned but not shown below are in state: closed)
Port State Service
21/tcp filtered ftp
22/tcp open ssh
23/tcp open telnet
80/tcp open http
443/tcp open https
Nmap run completed -- 1 IP address (1 host up) scanned in 3 seconds
tcpdump will show something like this:
[root@LinuxES-lab2 root]# tcpdump -nnni eth0 host 192.168.15.248 and not net 224.0.0
tcpdump: listening on eth0
14:20:55.020743 172.16.1.250.32783 > 192.168.15.248.21: S 3643020768:3643020768(0) win 5840 (DF)
14:20:55.022747 192.168.15.248 > 172.16.1.250: icmp: host 192.168.15.248 unreachable - admin prohibited filter
make sense right?
kmilev Mon, 03/23/2009 - 02:43
Thank you for the response! Actually, before posting here, I had already taken care of the ACL and had denied the FTP traffic to check if it will work... It didn't work.
By the way, after some additional investigation, I found that the problem is not on the router I've configured - it is on the upstream provider whose PA IP address space my router (and network behind it) is using. I have mentioned about another router (Cisco 2811) which experiences the same problem - the case here is the same, the provider is the same and obviously he has configured some kind of erroneous forwarding to TCP port 21. For example, when trying to reach FTP port on any unexistent (still unassigned) IP, located behind the network of the provider it opens a FTP session every time...
I'm definitely considering to change the provider! I'm trying to avoid thinking what other problems and misconfigurations he could have introduced in his "network" :-(
Anyway, thank you once again for the answer, I appreciate this!
BR,
Kamen
