Ciscoworks Discovery - Multiple duplicate devices after each discovery
jabeck018
Most of our devices are currently in DNS and the hostname is resolving correctly. However, I am seeing multiple duplicates (around 200) on each discovery where the device is added with the IP Address as the hostname/display name. Shouldn't Common Services recognize these are duplicates based on IP Address?
Common Services 3.1.1
yjdabear
It depends on what options are selected in a couple of settings in Device and Credentials - Device Discovery - Discovery Settings:
Module Settings
Layer 3 Discovery Protocols
Address Resolution Protocol (ARP)
Border Gateway Protocol (BGP)
Open Shortest Path First Protocol(OSPF)
Routing Table
Layer 2 Discovery Protocol
Cisco Discovery Protocol (CDP)
Ping Discovery Options
Ping Sweep on IP Range
Others
Cluster Discovery Module
Hot Standby Router Protocol (HSRP)
Global Settings
Preferred DCR Display Name
IPAddress
Host Name
FQDN
Preferred Management IP
Use LoopBack Address
Resolve by Name
Resolve by SysName
None
Here are the current discovery settings I have selected:
Module Settings:
Routing Table
Global Settings:
Preferred DCR Display Name - Hostname
Preferred Management IP - Use LoopBack Address
Update DCR Display Name
Update Default Credentials
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
