URL Filter Byass in IOS
Mar 20th, 2009
I know in an ASA that I can allow certain IPs/Subnets to completely bypass url filtering. Is this possible in IOS based URL Filtering? Can i set deny entries in my Java List to do this?
Thanks in advance!
vikram_anumukonda Sat, 03/21/2009 - 02:52
  • Bronze, 100 points or more
"ip urlfilter exclusive-domain permit/deny x.x.x.x or xyz.com "
Java filtering :
ip inspect name <> http java-list 1
access-list 1 deny host 1.1.1.1
access-list 1 permit any
<< the above code would block only java-applets from being downloaded from 1.1.1.1 and permit the rest >>
Vikram
vikram_anumukonda Sat, 03/21/2009 - 05:49
if you want to block java applets in conjunction with url-filtering, you will have use the below command
ip inspect name <> http java-list 1 urlfilter
