Intercepting 311 Calls - Unified Call Manager 6.1
Mar 20th, 2009
Is there a way so that when a user dials a particular number (specifically 311) that a custom message picks up - asks them if they want to continue with the 311 call to press '1'?
Thanks in advance for any responses.
Jaime Valencia Fri, 03/20/2009 - 08:54
not with CCM only, this would require Unity or CUC to intercept the call and then play the warning
if this helps, please rate
Jaime Valencia Fri, 03/20/2009 - 09:07
then it's all about routing.
create a CTI RP with DN 311, the partition needs to be reachable to users.
configure a call handler and record the message you want "if you're sure press 1, press 2 to hang up" or something
configure a call routing rule for forwarded calls with DNIS 311 and set it to transfer directly to greeting of above call handler
create a dummy call handler to transfer and set the transfer options to yes, ring subscriber at this extension 311. that's all you need for this one.
on 1st CH under caller input set (following my example) input 1 "attempt transfer to" and choose CH #2.
on input 2 you can set it to simply hang up
hope this makes sense to you
