Jerry Ye Fri, 03/20/2009 - 09:00
  • Cisco Employee,
What terminal emulation software are you using? If you are using CRT or SecureCRT from Van Dyke, you can log the session. If you are using HyperTerminal, you can capture the text under "Transfer". If you are using command prompt, you have to change the buffer to a very large number and cut and paste it.
HTH,
jerry
Giuseppe Larosa Fri, 03/20/2009 - 09:03
  • Hall of Fame,
    Founding Member
Hello Sivaprakasam,
whatever telnet client you are using there are logging options
you need to enable log to a file
then you do sh tech-support
then you stop logging and you have the sh tech in a text file on your PC
for example for putty is
change settings -- logging
select printable output only
on the file name box choice the filename you want to give to the file
with securecrt
file ->log session open a file dialog box where you can choice name and dir
Hope to help
Giuseppe
Mohamad Qayoom Fri, 03/20/2009 - 09:14
  • Bronze, 100 points or more
Or you can use the following if you are using command prompt:
telnet -f abc.txt 10.10.10.10
Mohamad
sivaprakasam81 Fri, 03/20/2009 - 09:30
Thank you!
I can log the file in my local drive. Can i transfer the file (like crashinfo file or image file) using telnet?
or
How can i transfer file using Putty?
Thank you.
sivaprakasam81 Fri, 03/20/2009 - 09:45
To use tftp, there is a need of workstation in the remote location. Is there any other way,where i can do the file tranfer without going for a workstation in the remote location LAN.
Thank you,
Mark Yeates Fri, 03/20/2009 - 10:26
  • Gold, 750 points or more
You can redirect the output of the "show tech" file via TFTP. I'm not sure if this is what you are looking for.
show tech | redirect tftp://1.2.3.4/test.cfg
Change the 1.2.3.4 to the TFTP server IP address, and change the test to what you would like to name the file.
HTH,
mark
