03-20-2009 09:45 AM - edited 03-15-2019 04:59 PM
We are considering forcing individuals to call other offices in our centralized deployment to use the interoffice dialing feature placing calls over the MPLS. We want to try to get an idea of how many calls go on between our offices. Is there a way to set up call counters with the first six numbers of a DID range, like 312384xxxx? Any suggestions would be greatly appreciated!
Rgds,
Vicky
03-20-2009 01:05 PM
you can configure a separate dial plan under CAR and tag the calls depending on what they match. you can configure that pattern starting with those 6 digits and tag them appropriately for reporting
java
if this helps, please rate
03-30-2009 08:30 AM
Hi Java,
Thank you for your post. Can you help me with where I need to configure the dial plan in CAR? Is there any configuration needed on the Call Manager side, or is this tracking set up only in CDR? Can you give me a little more info on where I need to set this up, where I enter the six digits to be tracked?
Please let me know.
Thank you!
Rgds,
Vicky
03-30-2009 08:34 AM
This only affects CAR and does not require anything to be changed in CUCM
Configuring the Dial Plan
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_1_3/car/carsycfg.html#wp1092310
java
04-27-2009 12:37 PM
Hi again Java,
So I have all the route patterns in place for tracking but it looks like all I can pull from the CDR application is % of traffic info. Do you know if there is any way to get an actual count of how many calls hit the pattern I put in place using the CDR application? Please let me know if you do.
Thanks again.
Rgds,
Vicky
