Port forwarding in Cisco ISR 2811
Mar 20th, 2009
Hi I have a Cisco ISR2811 running advanced ip services with CME and CUE in it.
I need to Port forward from the outside to the inside port 22 for SSH.
example outside ip address 1.1.1.1 inside ip address 10.100.100.10
I know I need the command
ip nat inside source static tcp <private ip> 22 <public ip> 22
However on my ACL to permit this.
would I permit from my outside IP address or from the remote site I want to be able to access this.
and then do I apply that ACL to the FA0/0 which is the public interface as ACL 101 inbound
thank in advance
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 03/20/2009 - 12:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Greg
Your acl would look like
access-list 101 permit tcp host eq 22
and then yes you apply it inbound on the outside interface.
Jon
GregL Fri, 03/20/2009 - 12:22
Thanks Jon I will give that a try next week.
