CaT 6500 problem with dot1q trunk to HP BL-C Blade Switch
Mar 20th, 2009
Not sure if anyone out there has a C-Class HP Blade server enclosure with a 10Gig HP BL-C Switch connected to a core 6500 using 802.1q trunk and EtherChannel:
Anyway, having issue with conenctivity:
I set up the dot1q trunks and added members on the BL-C, andl am unable to get the servers to talk thru the switches and the Cisco core (setup to allow default-all vlans)
Here is the scenario
- Servers are VM ESX 3.5. VMware is tagging using VST- where the V-switch is tagging, like in the document:
http://www.vmware.com/pdf/esx3_vlan_wp.pdf
- Here is the BL-C config (truncated)
/c/port 1
tag ena
/c/port 2
tag ena
/c/port 3
tag ena
/c/port 18
tag ena
/c/port 19
tag ena
/c/l2/vlan 2
ena
name "network"
def 1 2 3 18 19
/c/l2/vlan 3
ena
name "infrastructure"
def 1 2 3 18 19
/c/l2/vlan 4
ena
name "devtest"
def 1 2 3 18 19
/c/l2/vlan 5
ena
name "vpn"
def 1 2 3
/c/l2/vlan 6
ena
name "stage"
def 1 2 3 18 19
/c/l2/vlan 8
ena
name "iscsi"
def 1 2 3 18 19
/c/l2/vlan 10
ena
name "corecard"
def 1 2 3 18 19
/c/l2/vlan 20
ena
name "ecommerce"
def 1 2 3 18 19
/c/l2/vlan 30
ena
name "sql"
def 1 2 3 18 19
/c/l2/vlan 40
ena
name "blades1"
def 1 2 3 18 19
/c/l2/vlan 41
ena
name "vmbuild"
def 1 2 3 18 19
/c/l2/vlan 50
ena
name "blades2"
def 1 2 3 18 19
/c/l2/vlan 60
ena
name "blades3"
def 1 2 3 18 19
/c/l2/vlan 70
ena
name "blades4"
def 1 2 3 18 19
/c/l2/vlan 80
ena
name "AspectUIP"
def 1 2 3 18 19
/c/l2/vlan 192
ena
name "management"
def 1 2 3 18 19
/c/l2/stp 1/off
/c/l2/stp 1/clear
/c/l2/stp 1/add 1 2 3 4 5 6 8 10 20 30 40 41
/c/l2/stp 1/add 50 60 70 80 192
/c/l2/stp 1/port 1/on /fastfwd enabled
/c/l2/stp 1/port 2/on /fastfwd enabled
/c/l2/stp 1/port 3/on /fastfwd enabled
/c/l2/stp 1/port 18/off
/c/l2/stp 1/port 19/off
/c/l2/trunk 2
ena
add 18
add 19
/c/sys/syslog
host 10.20.3.24 -mgt
host2 10.20.2.30 -data
facil2 5
/c/ufd/on
/* /c/l3/if 250
* addr
* ena
/* /c/l3/gw 254
* ena
* addr
- Here is the Cisco Core switch config (truncated):
interface Port-channel100
description 20 Gbps trunk to Core2 t1/1 t1/9
switchport
switchport mode trunk
spanning-tree portfast disable
interface TenGigabitEthernet1/1
switchport
spanning-tree link-type point-to-point
channel-group 100 mode on
interface TenGigabitEthernet1/9
switchport
I verified the Etherchannel is up
No traffic seems to pass (dhcp requests, pings to static IP, etc)
Any ideas on what is wrong?
Yudong Wu Sat, 03/21/2009 - 12:00
  • Gold, 750 points or more
There are two trunks here.
- trunk between server and Blade switch
- trunk between blade switch and core switch.
Could you verify if both trunks are up?
Cisco command should be "sh int trunk".
The other thing is that Cisco does not tag native vlan on a trunk by default. So, you need to make the sure the other side does not tag native vlan as well.
By the way, have you created all the vlans on CAT6k swtich?
Yudong Wu Thu, 03/26/2009 - 14:20
1. Can you post output "show int trunk Gigx/y"
2. Did you check if all vlan is active in CAT6500?
3. My understanding is that there is another trunk between BL-C and server, is it correct? If yes, does that trunk up?
4. Configure a management IP on BL-C if possible, then configure a vlan interface (in the same management vlan) on CAT6500, try to ping BL-C IP to see if trunk can pass traffic correctly.
