03-20-2009 10:36 AM - edited 03-15-2019 04:59 PM
I have CCM6.0 and Cisco IP phones 7941 and 7961. Can I have different rings for incoming calls? Like I want a call coming for a certain extension to ring differently than others?
03-20-2009 01:02 PM
the only option is a slight different cadence on the tone.
not like having 2 completely different ring tones if that's what you were looking for
java
if this helps, please rate
03-20-2009 01:37 PM
thanks. I would like to be able to have a different ring (when my boss calls) than other incoming calls.
Not sure if that possible
03-23-2009 07:34 AM
not possible, as i mentioned the only option is a slight different cadence for internal/external.
there is no per user ringtone capability
java
