Set command to different privilege level
drolemc Thu, 03/26/2009 - 18:56
  • Silver, 250 points or more
Prior to the introduction of this feature, each command in a privilege level had to be specified with a separate privilege command. This feature introduces a "wildcard" option that allows you to configure access to multiple commands with only one privilege command. By using the new all keyword, you can specify a privilege level for all commands which begin with the string you enter. In other words, the all keyword allows you to grant access to all command-line options and suboptions for a specified command.
