Smartports
MICHEL.HEGERAAT Mon, 03/23/2009 - 00:53
Well, as far as I can see these are just basic ios command put in a macro, so your smartports are as great as the ios commands you put in....
I think I only used marcos on CatOS. I don't think cisco marketing machine was aware of these commands then :-)
Cheers,
Michel
Martin Ermel Mon, 03/23/2009 - 01:46
  • Blue, 1500 points or more
I think it could be a good idea if you have a few standard configurations that could be applied to interfaces. Like the interface could be used as an en-host port, a voice port or a server port - and if you want to enable e.g staff to change the 'function' of one of these ports with an easy one-liner; but it could also be work to have the macro available on every switch where they are needed - on the other hand they can be deployed with a net-config job and verified with baseline templates; so there are several pro's and con'sdepending on the kind of network, the number of changes and who is doing a change - which should be all considered before introducing them.
BTW, I only know of one customer who used it in the past...
