Web Attendant - Maximizes/Minimizes on each call recieved
Answered Question
Mar 20th, 2009
We have an issue where calls that come in force the web attendant console to minimize, them maximize. The only way I have been able to fix the issue is by reinstalling the application - but this wipes out all the speed dials and saved numbers.
Any one know what might be causing this and how to fix it without having to re-install it?
JP
Correct Answer by Rob Huffman about 7 years 11 months ago
Hi JP,
Have you tried to use this method to enable / disable "Pop to Top" on AC :)
Note: To toggle the pop-to-top feature on and off, press Alt + P.
There is also another method listed nicely by Met (with screenshot) here;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbe64a0/2#selected_message
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 03/20/2009 - 11:56
Hi JP,
Hope this helps!
Rob
