Translation between DMZ and Inside
Mar 20th, 2009
  • Purple, 4500 points or more
All,
If I have inside traffic going into the DMZ, would my static nat look like:
static (inside,dmz1) 10.0.0.0 10.0.0.0 netmask 255.0.0.0
We have several subnets of 10.100.0.0, 10.200.0.0, etc.
John
Overall Rating: 5 (2 ratings)
JamesLuther Fri, 03/20/2009 - 12:32
  • Silver, 250 points or more
Hi John,
Your NAT statement will do identity NAT. ie will not NAT at all, but will still keep in NAT table.
You are probably better of doing NAT exemption by doing
access-list no_nat permit ip 10.0.0.0 255.255.255.0 10.0.0.0 255.255.255.0
nat (inside) 0 access-list no_nat
Or switch off NAT control globally with
no nat-control
Jon Marshall Fri, 03/20/2009 - 12:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
James
think this may be a typo ? Assuming 10.0.0.0/24 is on inside and 10.100.0.0/24 is on dmz
access-list no_nat permit ip 10.0.0.0 255.255.255.0 10.100.0.0 255.255.255.0
Jon
John Blakley Fri, 03/20/2009 - 12:40
Which is more preferred? Statics or policy nat?
Jon Marshall Fri, 03/20/2009 - 12:45
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
John
Do you mean static NAT or NAT exemption. To be honest i haev always used statics but as James has pointed out there is little point if you don't actually want to NAT.
NAT exemption acl's are bi-directional anyway so there is no reason not to use them.
Jon
John Blakley Fri, 03/20/2009 - 12:48
I'm not going to need nat. I'm setting up a new firewall from scratch because I'm converting from a Symantec Gateway. I want to make sure that I can get traffic from my internal to the DMZ and DMZ back without translation. I thought statics would be the best way to do it, and so far mine looks like the one that I posted. I don't have it actually connected into the network yet; that won't be for a few weeks.
John
Jon Marshall Fri, 03/20/2009 - 12:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
John
If you don't need NAT at all on your firewall you could turn off NAT as suggested by James.
As i say i have always used statics so i can't disagree with what you have proposed ie. just to be sure we are saying the same thing
static (inside,dmz1) 10.0.0.0 10.0.0.0 255.255.255.0
means the 10.0.0.0/24 hosts are on the inside and they will be presented to the dmz as the same.
Jon
