Showing First name then Last name in the phone directory
Mar 20th, 2009
corporate directory shows last name, first name.
is there a way to show the first name then last name in the corporate directory without the need to use the SDK and XML integration.
note: communications manager version is 6.1 and integrated with the active directory LDAP.
Anonymous (not verified) Thu, 03/26/2009 - 14:38
There is no way of changing it through a GUI. If you want it, you can save the original .asp, change the setting and use that.
