router with 802.1q strange request
Mar 20th, 2009
it is a strange request but I have 2 sites with a layer2 link where 802.1q is supported.
For a while, I need to install a router on one side to separate the flow.
But
1 - vlan 1 must be share by both sites with differents networks and the router must terminate the flow and route the trafic.
2 - Others vlans are no routable but must be pass through the router.
For second request do I need to use bridge mode ?
config are like this
________________________________
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.1.1.1 255.255.2550
interface FastEthernet0/0.100
description VLAN
encapsulation dot1Q 100
interface FastEthernet0/1.1
ip address 10.1.2.1 255.255.255.0
description VLAN
Giuseppe Larosa Sat, 03/21/2009 - 06:43
  • Hall of Fame,
    Founding Member
Hello Eric,
the possibility to bridge over vlan subifs is IOS and platform dependent.
You can verify if you router accepts it.
You need to define a bridge-group for each pair of vlans you want to bridge or it will be a terrible mess.
bridge 1 protocol ieee
int f0/0.100
no ip addr
bridge-group 1
int f0/1.100
no ip addr
bridge-group 1
then bridge-group 2 for another pair of Vlans and so on.
Verify also the max number of bridge-groups you can create they can be less then the number of vlans that need to be bridged.
I would consider if it is a possible solution to bypass the router totally: actually almost all vlans just need to be propagated like in a l2 trunk.
you can remove vlan1 in the list of permitted vlans on both sides and you have a working solution with no bottlenecks.
Locally on each site one device will provide the default gateway for the vlan1.
Only possible problem of a partitioned vlan1 is vtp: if you use vtp you need to deploy it in two vtp domain on the two sides of the link
Hope to help
Giuseppe
