03-20-2009 02:30 PM - last edited on 03-25-2019 04:05 PM by ciscomoderator
All,
Wondering if anyone knows if the NM-1FE-FX will work in a 3745 router. I've looked up the NM-1FE-FX on the Cisco Solution Finder, but the 3745 doesn't even show up on the list. I assume that the 3745 is not listed because it has been discontinued. Anyone know? Says this module does work in the 3725.
Appreciate the assistance.
Solved! Go to Solution.
03-20-2009 02:40 PM
03-20-2009 02:40 PM
Yes, it's supported.
__
Edison.
03-20-2009 03:31 PM
Outstanding, thanks...
