03-21-2009 04:28 AM - edited 03-15-2019 05:00 PM
Dear all,
I am using CCM 5.1. Suddenly I am facing a problem to generate the Call Report by CDR. Last some days In my Server Outgoing calls not Generating but incoming call is genrating normally.
plz help me as soon as possible.
Thanks & Regards
Madhab
thanks
03-26-2009 02:59 PM
Under Select Call Types, Select Outgoing under Select QOS, Make sure that you have selected all the parameters.
Confirm whether CDR files are populated with the correct call classification codes.
03-28-2009 12:42 AM
hii
yes I am confirmed about that. bcz what parameter I have selected here the same I am selected for another cluster. and that cluster report is generating properly.
so I can't understand whats wrong with this cluster.
regards
madhab
03-28-2009 09:06 AM
try restarting service..
