JORGE RODRIGUEZ Sat, 04/18/2009 - 10:50
  • Green, 3000 points or more
Prakash,
First you did not specify which ccie lab you refert to, voice , rs security ? either or start looking at the blue print in ccie's labs ..
For example for ccie rs lab blue print.
http://www.cisco.com/web/learning/le3/ccie/rs/lab_exam_blueprint.html
ALL ccie's exam blue print in general
http://www.cisco.com/web/learning/le3/learning_career_certifications_and_learning_paths_home.html
second like I did couple of months ago, asking here is the right place but additional reserach may be required like researching in google to get the right materials and information for study approaches for written and labs exam and find best place to suit your needs.
I found personally very useful http://www.ipexpert.com/ materials, and if you have some money to invest you can buy Virtual Racks from
http:// proctorlabs.com and use ipexpert.com ccie study materials to do your labs based on ccie blue print requirements and ipexpert.com workbooks from ipexpert.com using real cisco live equipment.
You may also check http://www.internetworkexpert.com/ , I have not used this but ipexpert.com instead but internetworkexpert seems to have exellent materials for both written and labs, heard very good reviews as well.
ccbootcamp Fri, 04/24/2009 - 07:18
  • Gold, 750 points or more
The best place to start is with a Cisco Learning Partner at www.ccbootcamp.com - The other training companies mentioned are considered to be "grey market" and are not supported by Cisco. CCBOOTCAMP is one of the few companies to offer authorized CCIE training.
