Remove the default rings from the phone
Mar 22nd, 2009
Hi all,
My customer wants to remove all the ringtones (except chirp1 and chirp2) from the phone. How do i remove? I removed ring 7(ring7.raw) from tftp. But still it showing on the phone? Need tftp restart? Once i removed these rings can i restore it back?
craiglcve Sun, 03/22/2009 - 14:24
You need to modify the Ringlist.xml file and DistinctiveRinglist.xml file with the rings you want to be displayed on the phones. Upload the ringlist files onto all CallManagers (Pub - Subs) in the cluster along with any new ringtones. Then you need to restart the tftp service on all servers in the cluster. If you modified a ringlist and you dont see the changes on a phone then maybe you didnt put the ringlist on a CallManager that the phones are registering to or the service needs to be restarted. Hope that helps.
